@praphotSYZN3
First, there is no sequence of FPCW.
I assume you mean FCFPW , Fill+Cool+Fill+Pack+Warp, analysis sequence , right?
Now, CFPW , Cool+Fill+Pack+Warp, is where Cool starts with cavity instantaneously filled with melt as melt temperature set.
The starting point for the Cool iterations.
If you do a preceding simulation of Fill then Cool , FCFPW , Fill+Cool+Fill+Pack+Warp,
it will use the melt temperatures variations during filling as input to Cool.
This will then be starting point for the Cool iterations.
In general the melt temperature variations should be kept with relatively low variations.
The general rule is 2-5C.
Hard to accomplish many times, filling profile might help.
Anyway, this means low melt temperature variations, and more efficient to use CFPW , Cool+Fill+Pack+Warp.
This is also the recommendation of today.
If I recall correctly there were discussions way back then which would give best result in terms of Warp.
And I think it ended up with to use CFPW analysis sequence as recommended analysis sequence.
Anyway, I am basically always using CFPW , Cool+Fill+Pack+Warp, today, and that would be my recommendation.
Note: Those available analysis sequences are for Midplane and Dual Domain, DD, mesh types.
3D does not have this option , always Cool + the sequence,
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
