Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
保存在My AMI 2021.1 Projects目录下的runstudy临时文件会自动删除吗
3 ANTWORTEN 3
Nachricht 1 von 4
1292909313
77 Aufrufe, 3 Antworten
3 ANTWORTEN 3
Nachricht 2 von 4
bernor_mf
als Antwort auf: 1292909313
@1292909313
First a google translation :
"Will the temporary files of runstudy saved in the My AMI 2021.1 Projects directory be automatically deleted?"
Yes, they should be removed when analysis completed.
But they could be kept by using -keeptmp argument
to specify that any temporary files created should be retained.
Moldflow Insight Help | The runstudy utility | Autodesk
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Tags (1)
Nachricht 3 von 4
1292909313
als Antwort auf: bernor_mf
I use Autodesk Moldflow Insight 2021.1 Command Shell to run runstudy, why do I use different mesh and boundary condition files, the saved result file core is the same, and how can I set the result file core name by myself
Nachricht 4 von 4
bernor_mf
@1292909313
The study has link to results, and you can see that in Moldflow Synergy by right-click om study and Properties.
It will show result pre-fixes.
Is generated by Synergy and linked.
The linking of result files can be controlled in Options.
The issue you probably depend on how Duplicate or Save Study As studies keeps result link.
In Options, tab Result :
Review "Duplicate Studies".
Probably set to: Duplicate study - include results linked from original study
Change to: Duplicate study - do not include any results
Hope this resolves your issue.
Berndt
