Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Anomaly in Clamp Force Results
4 REPLIES 4
vgvimalkanth
609 Views, 4 Replies
Hello, I'm using Autodesk Moldflow Insight 2019.
In that I'm facing an anomaly in Clamp Force Results. The Clamp Force: XY Plot shows the maximum tonnage of 503.3 tonne, while the result log shows the maximum clamp force of 400.46 tonne.
Can someone help me with this difference of result. I have also attached images for your reference.
4 REPLIES 4
mppkumar
in reply to: vgvimalkanth
Hi @vgvimalkanth
That particular time frame results are not printed in Log file - Results summary
recommend to  consider clamp force  XY - Plot values
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
It may be due to Intermediate results are not calculated& you need to  increase the frequency that the intermediate results are recorded.
Suggest you to follow as shown in below image and change the parameters in solver settings ( 4, 5, 6)
you will get better clamp tonnage value prediction. But it takes more simulation time
Hope helps your query
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Thank you for the reply.
vgvimalkanth
in reply to: mppkumar
Thanks.
