Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello, I'm using Autodesk Moldflow Insight 2019.
In that I'm facing an anomaly in Clamp Force Results. The Clamp Force: XY Plot shows the maximum tonnage of 503.3 tonne, while the result log shows the maximum clamp force of 400.46 tonne.
Can someone help me with this difference of result. I have also attached images for your reference.
Solved by madhukeshwart. Go to Solution.
Solved by mppkumar. Go to Solution.
That particular time frame results are not printed in Log file - Results summary
recommend to consider clamp force XY - Plot values
It may be due to Intermediate results are not calculated& you need to increase the frequency that the intermediate results are recorded.
Suggest you to follow as shown in below image and change the parameters in solver settings ( 4, 5, 6)
you will get better clamp tonnage value prediction. But it takes more simulation time
Hope helps your query
