Anomaly in Clamp Force Results
vgvimalkanth
vgvimalkanth
Hello, I'm using Autodesk Moldflow Insight 2019.
In that I'm facing an anomaly in Clamp Force Results. The Clamp Force: XY Plot shows the maximum tonnage of 503.3 tonne, while the result log shows the maximum clamp force of 400.46 tonne.
Can someone help me with this difference of result. I have also attached images for your reference.
mppkumar
Hi @vgvimalkanth
That particular time frame results are not printed in Log file - Results summary
recommend to  consider clamp force  XY - Plot values
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
madhukeshwart
It may be due to Intermediate results are not calculated& you need to  increase the frequency that the intermediate results are recorded.
Suggest you to follow as shown in below image and change the parameters in solver settings ( 4, 5, 6)
you will get better clamp tonnage value prediction. But it takes more simulation time
Hope helps your query
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
vgvimalkanth
Thank you for the reply.
vgvimalkanth
Thanks.
