Analysis in linux platform
users,
Could anyone help in executing Moldflow  in Linux platform.
any reference document could you helpful.
regards,
B.Vasanth
kristen.kilroy
Hi @Anonymous,
The help documents describe how you can launch through either the command line of Linux or via the Simulation Job Manager. I've listed a couple links below. To run through the command line, you would use the "runstudy" command. The help documents describe this, however I have also recorded a demo of using this command as reference (note this was using the Windows version of Insight's command line instead of Linux).
Hope this helps!
Kristen Kilroy
_______________________________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
kristen.kilroy
Hi @Anonymous,
I wanted to check in to see if the links I provided and the demo allowed you to successfully launch an analysis on Linux.
If yes, feel free to mark my previous comment as the solution to help others find these resources. If you run into any trouble, I'm happy to help!
Kristen Kilroy
