When I start the analysis, showing the below dialog box. What's the problem? Here I have attached sdy file of experiment.
Hi
Can you share the error message from log file
Hi Sanjay,
just a control question:
did you install Insight solver as well on the new workstation?
Moldflow Synergy (UI) and Moldflow Insight (solvers) should be installed.
What does Analysis Log say?
If C and empty it means solvers not installed.
See: Job fails with "c" and "i" listed in the Log in new installation of Moldflow Insight
Check that the service for job manager is running and not stopped: amijm.exe
Hope this helps.
Berndt
There can sometimes be an issue if the study file names are too long, can you run studies with shorter names without a problem?
Yes the analysis log is totally empty. I am checking now what you mentioned.
Regards
Sanjay Paul
