Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
About Cooling Channels
7 REPLIES 7
Message 1 of 8
ersin_degin
393 Views, 7 Replies
Hello Moldflow Users,
I have a question about Moldflow. In Moldflow, we can import and make runner entries in 3D. But does the same apply to cooling channels? Do you have any idea about this subject?
7 REPLIES 7
Message 2 of 8
mason.myers
in reply to: ersin_degin
Hello @ersin_degin ,
I am not sure I understand your question.
You can import IGES curves and assign properties to make cooling lines.  You can also import the CAD of the cooling channels, assign them to Channel 3D, and then use the Centerline tool to create curves from the CAD model.  You can also import the 3D CAD of the cooling channels and simply mesh them to 3D using the Channel Mesher.  3D meshed cooling channels require CoolFEM to solve.
Mason
https://help.autodesk.com/view/MFIA/2024/ENU/?guid=MoldflowInsight_CLC_NewUser_Import_and_Export_Sup...
https://help.autodesk.com/view/MFIA/2024/ENU/?guid=MoldflowInsight_CLC_WhatsNew_What_s_New_in_2018_2...
https://help.autodesk.com/view/MFIA/2023/ENU/?guid=MoldflowInsight_CLC_Modelprep_Mesh_Meshing_the_mo...
Message 3 of 8
ersin_degin
ohh sorry i wrote by voice command.When i import the CAD of the cooling channels, i could not the assing them to Channel 3D.
Message 4 of 8
mason.myers
It appears that you meshed the Cooling Channels as Dual Domain part surface mesh.  If you change your mesh type to 3D, you should get options to change the CAD to Channel 3D.  You then need to add 3D inlets and 3D outlets, and use the Channel 3D mesher, not the Generate Mesh option.
Mason
https://help.autodesk.com/view/MFIA/2023/ENU/?guid=GUID-C0E87C79-9CFF-4726-B2E0-2512DA855249
Message 5 of 8
ersin_degin
Hello @mason.myers
I changed my mesh type to 3D, however the button of 3D Channel Mesh is not active.I have no idea what i will do.
Message 6 of 8
bernor_mf
@ersin_degin
There are a couple of requirements that needs to be met.
From on-line help:
3D channel mesh
Before attempting to use the 3D channel mesh tool, check that the following requirements are met:
  • A part model is in your study and has been meshed.
  • The analysis sequence includes a Cool (FEM) analysis.
  • An injection location has been set for the part.
  • A CAD representation of the conformal cooling body is in your study and its Properties are set to Channel (3D).
  • Channel (3D) Inlets and Channel (3D) outlets have been assigned. There should be an equal number of conformal cooling inlets and outlets.
The picture shows only the cooling channel geometry.
Doing according to above check list should sort out the issue.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 7 of 8
ersin_degin
in reply to: bernor_mf
Hi
Thank you very much.
I realized that ranking is important.
I handled all my transactions without any problems.
Have a nice day.
Message 8 of 8
bernor_mf
@ersin_degin
Thank you!
Good to hear your issue were resolved. 😊
Berndt
