Announcements
3D baffle vs 2D
romano.miglietti
3D baffle vs 2D
romano.miglietti
Hello everyone,
I created a study just to explore a bit the possibilities of the software and i was trying to understand the differencies between the channels simulated in 3D or with beams.
If i simulate a very simple mold, like the one in the picture here below (without the baffle), i obtain quite similar results.
But what if i want to add a baffle? I modeled a baffle in 3D and then i tried to model the same with beams, what i get is a very different temperature result on the part. To model the baffle with beams i gave to it the same diameter of the one in 3D. You can see the differencies below.
So the question is why i get this difference and wich is the correct or best way to simulate this situation?
bernor_mf
when modelling beams, cooling channels has Heat Transfer Effectiveness (HTE) of 1.0.
Baffles has HTE 0.5, as beams goes up and down and overlaps.
Channel 3D does not have such properties.
(Wonder if assumed HTE 1.0 for all Channel 3D?)
You could test by setting Baffles HTE 1.0, to see if more aligned Cool result with Channel 3D.
Please, update community of your findings.
Thanks.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
romano.miglietti
Hi Bernor,
thanks for the reply, i already tried that but it seems that nothing changed...
I also attach the sdy files.
romano.miglietti
anyone has some other idea?
bernor_mf
Hello Romano,
I have looked at the studies at time slots, and from what I see the baffle HTE does not have an effect.
The same if HTE 0 , 0.5, or 1. HTE 0, means zero heat transfer, and that should been seen in result when changing.
Circuit heat flux is the same...
Tested with BEM method as well.
A bit unexcpeted to me and I think Autodesk tech support should shed som light over this.
General about modelling:
The baffle can have one curve since 2018.2
The construction of bubblers and baffles has been greatly simplified.
So you do not need V-shape as of :
Baffles
Baffles is ½D end point from drilling end point.
Have an idea, see:
Cool to improve Baffles and Bubblers ½D end point from drilling end point
(Kudos it if you agree. Smiley Happy )
The 3D baffle you modelled has higher pressure drop.
The overall diameter is 11.3, but half the area is a diameter of about 8.
The baffle beams has D 11.3.
The 3D baffle does not have drill shape in top. Affects flow around top.
The coolant of beams heats up more.
So the 3D baffle as modelled seems to be more efficient.
Hence the lower temperature.
I think the modelling should be aligned to baffle beams and basic rules first.
Then, align 3D baffle modell to get closer results.
Assume there will still be differences.
Hope this helps somewhat.
Berndt
romano.miglietti
Hi Bernor,
I get what you are saying.
I'll try to do what you suggest. Thank you very much
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
