2021.2 Bug - beam elements not visible
prabu_Karunakaran
prabu_Karunakaran
Hello Autodesk,
I am testing 2021.2 version - Moldflow Insight
This version UI is faster , but when i moved the beam elements into different layer , Beams are not visible. but when i tried to open the same .sdy file into 2021.1 - its visible
There is bug with 2021.2 version - please solve it
Prabu Karunakaran
Lorena.Rivas
Hi @prabu_Karunakaran
Do you know if there is a solution for this?
A customer with an active subscription is having the same issue with 2021.2 version (attached image)
Lorena Rivas
Lorena.Rivas
I just saw another post
 https://forums.autodesk.com/t5/moldflow-insight-forum/problem-with-job-manager-moldflow-2021-2/td-p/...
And apparently it will be address in a future release.
Lorena Rivas
mason.myers
I have seen the same issue with my beams as well.  If you simply click on a Connectivity diagnostic but don't click on any element, my beams return back to the normal display.
Mason
