Show only
Search instead for
I created a block for a 3 port valve. The plantpartconvert command worked. I placed 3 ports, and checked to ensure that 3 ports were showing in the block. Next I created a new component in the catalog. I chose 3 ports on the first screen when creating a catalogue object. I continued thru the catalog entry, then when I chose the block to bring in, a pop up screen title "Select Block Definition" appeared, stating "There is no block has 3 ports in the selected DWG file". I went back, did a check and the block is in the drawing chosen. Has anyone ran into this problem? What to do next?
