The filling pressure turned out to be higher than that of the actual molding.
Thank you for your continued support.
As I was unsure where to post this inquiry, I’ve decided to submit it here.
Recently, I tried to compare actual molded products with the results from a simulation to see if similar outcomes could be reproduced. However, despite using the same molding conditions, same geometry, and same material, the analysis showed a significantly higher filling pressure.
Could there be any possible factors that might have led to such a discrepancy?
I would greatly appreciate your guidance.
2 Comments
kedenSHFQD
@keita.watanabe
Hello Keita,
You might have better luck posting this in the Insight Forum.
Here is the link.
Moldflow Insight Forum - Autodesk Community
Good luck,
Kevin
keita.watanabe
Hello Mr.Kevin.
Thank you for letting me know where to post. I’ll try asking the same question at the place you suggested.
Regards.
