Adding a fourth option for plot scaling: Symmetrical. Especially helpful for deflection interpretation.
The biggest scalar value of, for example deflection, linked to the plot should be used as the default value for positive but also for negative direction. This pre-defined value can be adjusted in the plot properties to control both limits, positive AND negative. Advantage: Green = seemingly good result for many people = zero deflection. -> Expectation = depiction. Also the direction of the highest deflected area can be seen easier.
Example: Deflection, X-component plot -> Deflection -1.5mm / +2.2mm -> Default symmetrical scaling -2.2mm / +2.2mm -> dark red at +2.2mm deflection, "light"/greenish blue at -1.5mm -> green = 0mm deflection, biggest deflection in selected direction can be seen at first glance.
best regards
Andreas Rötzer
