Show the weight and percentage of resin injected per gate.
In the flow analysis results, there is a result called "Grow from".
But go futher on this, please show the weight and persentage of resin injected per gate of resin filled in the cavity.
6 Comments
juno
good!!!!!
vasyabc
Yes,
This would be really helpful in calculating when its family mold with different volume.
D50
good
M.Brassel
There is at least the "Throughput" result, which gives the throughput of beam elements of the runner system in cm^3.
See: http://help.autodesk.com/view/MFIA/2019/ENU/?guid=GUID-594D2B54-E589-41F2-8979-724A30F3AC33
Though it's not the mass, weight or percentage, I hope that helps you.
mpouliot
Observer
good
raalteh
For the sake of transparency ... Our solver developers looked at this and there are scenarios that are hard to resolve problem with 'grow from' with valve gates. This would build on top of this problem.
We will need to resolve the grow from first.
