Selected object should be highlight in the layers
Hi all ,
My idea is Once selecting the Object from graphic window it's should be highlight respected Layer
Thank you
B. Suresh
3 Comments
bernor_mf
@barmasuresh
did you try "Highlight Layer" in Layer pane?
The flashlight symbol, and is off by default (greyed out).
If you turn flashlight on:
1) Click an entity in graphics window, and a frame is seen around layer name
2) Hover over layer name in Layers pane, and entities will be highlighted in graphics window
The highlight color could be changed in Options, tab "Background and Colors"
Does this help?
Berndt
barmasuresh
Thank you Bernor
Thanks Suresh & BERNOR_MF
This works both the ways excellent either by selecting the element or by selecting the layer
This highlights both the ways
Thanks again
