Show only
Search instead for
Mismatching units is annoying. Are you running on linux via runstudy?
If you are using runstudy, you can add "-unit metric" to the runstudy command.
As a work around so you can see existing log files in metric (cm^3 and MPa) you can use the studyrlt command.
studyrlt <study name> -exportoutput -unit metric This will create a new text file with the log data in the correct units.The -unit command can be set to SI, Metric, or English.
As background information; the solvers (whether on linux of windows) run using SI units. so whether you are starting an analysis by hand on Linux of Windows should be the same.
The GUI will have an understanding of which unit system the end user is using, and the user interface will present the results in the unit system the user is requesting.
Jerremy's command line option was put in place exactly to make the 'command line' aware in which unit system you want to see the results presented to you. It will use the exact same code to convert, as the user interface at that point.
If you believe this does not meet your expectatations, you may create a discussion forum item and see what can be done to help further, but I don't think this is really an item for the 'Idea Station'. I will archive this item for now.
