Minimum packing pressure
I think most of us use the default 80% of injection pressure for packing pressure in the first simulations of a product.
Sometimes the injection pressure is not too high and thus the packing pressure would not be enough to compensate shrinkage properly. (Below 30-40 MPa).
I would like to suggest adding a "Minimum packing pressure" option to avoid unnecessary reruns of simulations because of improper packing pressure.
So if 80% of injection pressure is below the specified "Minimum packing pressure" value, then the minimum packing pressure value would be used instead.
I know with experience you can estimate pressure, but with more injection locations and on a big and complex part, it is not easy, but the computation time is high.
Thank you!
