Maximum & Minimum values from the result scale should be available to copy.
Maximum Minimum values from the results scale should be available to copy.
This feature should work with All Frames / Per frame / Specified Scales.
for e.g. when I click button on scale to copy values, it should copy Max. and Min. values and when we paste these values it should show Like below.
(243.4, -237.1) Deg. C Temp at flow front
(78000, 0.000) 1/s Shear rate bulk
(9.483, 0.2358) % Volumetric shrinkage at ejection
(2.689mm, -2.158mm) - Deflection, all effects: Deflection
(1.256mm, -1.265mm) - Deflection, all effects: X Component
(1.256mm, -1.265mm) - Deflection, all effects: Y Component
(1.256mm, -1.265mm) - Deflection, all effects: Z Component
