Material Search Filler Data Parameters
Good Day All,
All materials in the Moldflow database should have a parameter for the Filler data. Currently, you can't specifically search for unfilled materials.  Also, materials with Confidential filler information should be listed as confidential in a search. You can see it if you look at material details, but not on search. So I propose two things shown in red below, a parameter called Unfilled and Confidential fiber/filler to be added so all materials can be searched for their filler description.
Jay Shoemaker
5 Comments
bernor_mf
Hello Jay,
I second the idea.
Similar has been raised by Beth (@beth.mollica ) four years ago (08-28-2017 ). Nothing done yet.
A way to search for "unfilled" materials in the Moldflow material database
Berndt
RayScherer1014
Community Visitor
Ditto - This is frustrating.  I go through this often.  Thanks for requesting.
raalteh
As a (potential) work around for now, you can filter the search result by adding a column 'filler %' and ordering that column..
raalteh
Status changed to: Accepted
yes, this is already there in Fusion Injection molding
raalteh
Unfilled was added in the 2024 release.
'Confidential' is not yet available.
