Macro
Macro
Running Macro option will be available for first instance of synergy window only.
Next instance of synergy will not be able to run macro.
It should be possible to run march in every instance synergy window.
9 Comments
MichaelSchoo5437
I know this is an old point but wanted to emphasize it as it really influences our work with the software.
We have defined several macros and commands by which we work with the software. Examples would be
a.) generation of wall thickness results to be exported
b.) marking of standard results for report
Normally we work with multiple instances of the software. Every time we want to export some results, we have to
change the opened projects as we only have access to macros/command line on the first instance.
It would be very helpful to have macros/command lines available in every instance.
Michael
raalteh
This has come up on a few times and looked at before. The Moldflow API is depending on OLE, and its hard/impossible to direct to a specific instance.
The request is valid, we have to check the feasibility.
madhukeshwart
There must be something like, switching to different instance.
It you activate a window or by some commond, which  direct to a specific instance, instead of it is available for first instance of synergy.
I don't think it is impossible, some loop hole/logic to activate
raalteh
This issue is a duplicate of the issue here. That issue already had collected a Kudos, so I think we will follow that instance of the request.
raalteh
Status changed to: Gathering Support
Duplicate request of: http://forums.autodesk.com/t5/simulation-moldflow-ideastation/macro/idi-p/3789158
I'll transfer the Kudo's from this to the other issue
raalteh
Status changed to: Accepted
We start a Synergy program first, next we start the second Synergy program in another window.
we wish to use macro program in secondly Synergy program also.
The reason is always because it opens plural Synergy programs, and it performs duties.
raalteh
This is a long standing request by a good number of users. It's actually reported by others on teh idea station already, for instance  http://forums.autodesk.com/t5/simulation-moldflow-ideastation/macro/idi-p/3789158
I will mark this as a duplicate.
Please try the upcoming beta though ... 🙂
raalteh
Was implemented in 2017(I believe)
