Gate size as property and with visible feedback
That would be easy - defining a gate and setting the gate size as direct property included as value in the visible cone, maybe with visual feedback (real size of cone / gate as cylinder).
Not really my idea - but Javiers suggestion to post it... 😉
https://forums.autodesk.com/t5/moldflow-insight-forum/premature-freeze-off/td-p/2861032
And even if there is no "flow" or shearing in the cone then, it should give a better prediction of gate freeze of with that.
I forgot: The value should also be saved in the log file - and should be seen in the comparison table, when comparing two or more analysis.
Best regards
Harald
