Diagnostics for Mold Temperature Settings
I would like to have the Mesh Diagnostics for "Mold Surface temperature" in Part element properties.
For considering the mold temperature variation without cooling anaysis, you will set several temperature
across the part.
But if you want to checkout where you have set and what value you have set,
what you can do is to display each property dialog again, or run the analysis and see temperature results.
both of them takes time.
So I want this function.
Synergy have the simular function for DD"Thickness" so I sure you can do it.
Adding to that forget about displaying Mold Surface Temperature "profiles" .At least If you can see the
first value in the profile,  I can check where I have set or not.
Thank you.
