Cutting plane tool
Cutting plane tool
Add a cutting plane tool within a desired LCS location with  the ability to rotate and move  the plane about any axis (XYZ).
1 Comment
justin.bonfili
Autodesk Support
This would be helpful to also be able to select a different LCS instead of the default global for various plots.  For the temperature probe plot below, it would be nice to be able to generate the probe cut using a LCS for reference instead of the global.  If the user would want a cut across the part parallel to the LCS XY plane, they would need to use trig or trial & error to figure out how to get the cutting plane oriented correctly.
