This is a very simple one - in fact so simple that for years I couldn't understand why it's still unchanged... But to the point:
How many times - when running a full analysis sequence (like Cool(FEM)+Fill+Pack+Warp) on a large, time-consuming model - did you realize some packing profile changes are needed only when Insight was only doing the Filling stage (just an example, and probably not the most extreme one)? OK, so - knowing the packing profile has had no influnce whatsoever on the results so far (with the Filling stage at some 75%) - you introduced them in the Process Settings, and while presented with the routine "Create copy", "Delete" or "Cancel" dialog window you just clicked on "Delete" in the hope it will just "breake" the sequence (so that after Flow is compeleted, you will need to "Continue Analysis" so that Warp iis started)?
While in reality, Insight indeed deleted all the Filling progress so far, so that you had to start from scratch (well not exactly - Cool results would stay intact in this particular scenario; not much of a consolation)...
So PLEASE, do make that "Create copy", "Delete" or "Cancel" dialog window more intelligent! And I mean it in 2 ways:
- be more informative, and inform you which results would actually be deleted after you presses that button
- be smarter, i.e. not delete results that would have been perfectly valid if left at their current stage at the moment while carrying on...
Thanks.
