Checking Connectivity of gates with part
9 Comments
bernor_mf
I agree on this idea.
As described, if only one gate is connected, it will show full system as connected even if not.
Should be a smarter function, a check box, where you select sprue entrance beam, and check that branches and gates are connected,
and gates connected to cavity.
M.Brassel
I second this. Until now I hide some elements of the part so that the gate regions have no visible connection anymore. Then I use the connectivity check restricted to visible entities.
I do the same... I put the manifold on a separate layer, turn it off, then do a connectivity diagnostic restricted to visible entities.  If there was a gate connectivity diagnostic, I'm sure that would save a step.
Similar to this, the cooling circuit diagnostic could use some work.  Sometimes it doesn't pick up disconnected baffles.
mppkumar
@Anonymous & @M.Brassel
I agree with your comments and i also follow the same procedure... but it will be good if we have a diagnostics tool
It saves time for us Man Happy
raalteh
Status changed to: Accepted
xusho
This has been implemented in Moldflow 2018.1 release.
mppkumar
Wow.... good news @xusho
mppkumar
@xusho
can you please move this idea to "implemented" tab
Pradeep Kumar
madhukeshwart
can you please move this idea to "implemented" tab @raalteh
