Birefringence Reduction DOE
We are working with Moldflow Insight 2016 and attempting to do a study around Birefringence.
I am looking for a way to run a Fill, Pack, Warp simulation with a DOE process optimization that revolves around birefringence.
When reviewing and attempting to find a solution the best option I could find would be as follows
1: Create a DOE in a statistics software (Minitab)
2: Enter and run all of the corners of the DOE as individual studies
3: Export the retardance data as a XML file for each study
4: Import that data into the correct column in Minitab
5: Continue on with the statistical DOE in Minitab to determine the optimum process conditions for that particular mold
Is there any built in way to run a DOE that would be able to take care of all of this shuffling or allow the mass exporting of data to reduce the amount of shuffling required?
Could this be added?
Here is a discussion that was had on the insight forum
http://forums.autodesk.com/t5/moldflow-insight-forum/moldflow-birefringence-reduction-doe/td-p/65533...
