AMI 2021 : Bring back > keep nodes with BC when doing purge nodes
Working with meshes it is often very useful to keep, for example, BC injection location at node.
Delete triangles or tetras.
Then purge nodes.
In AMI 2019: the node with BC, boundary condition, Injection Location and connected node is kept.
You could then remesh, keeping this Injection Location and node.
(If "Apply extra refinement near gates" should be used.)
In AMI 2021: the node with BC, boundary condition, Injection Location and connected node is purged too.
You need additional operations to position it again...
(Why has this been changed, anyway?)
Please, bring back purge nodes to keep nodes connected with BC.
Thanks.
Berndt
2 Comments
agree with berndt
bernor_mf
I tested this in Synergy 2021.2, and the node with BC, boundary condition, Injection Location and connected node is kept.
As well as nodes that were at BC for cooling inlet, injection location at runner beam, venting location.
( Synergy Build - 20220309.0544_C3L3 )
Thank you for fixing this!
Berndt
