Ability to change sphere size for XY Probe Plot
Add feature to allow sphere size to be adjusted (to match a model) when showing result in XY plot.
Current spheres that are placed on the model cannot be changed. For relatively small over-molded parts such as semiconductor devices/sensors, this sphere can easily cover an entire section/body/part.
6 Comments
I believe with shift and right mouse button depressed dragging up and down will change it.  Dragging up increases and dragging down decreases.  You may need to hit refresh: Results Ribbon > Windows Box > Refresh.
I would definitely like to be able to control the size of these spheres better, though.  I'd also like to be able to control the size through the API so that there is more consistency in our automatic reports.
Correction... Shift+LEFT Mouse Button+Drag up/down
Thanks for your message.
I have tried it ...shift + left mouse button + drag up/down... but it does not work.
I hope you are not talking about zoom in/out. That I know how to do but that is not what I want.
What I want is to be able to reduce the dot/sphere size relative to my model when plotting results in XY plot (e.g. pressure XY plot).
Harry
My left mouse button is set to "select" so maybe that's what's different.  Here's a screencast of what I'm referring to:
http://autode.sk/2b1dd8x
The Shift + Left mouse button seems to be working only with the warpage anchor. I would also like this feature, but with every symbol, for example injection cones.
lothar.weber
Not working with MF 2019 😣😵
New ideas regarding this Topic / Issue?
THX
