Node layer number result is not a default result. It is a bit hidden, as it is generated after a while when 3D Fill or Flow analysis starts.
To access this result, you first start 3D Flow, then when analysis done the initial set up.
When:
WARNING 304920
WARNING 304930
WARNING 304940
appeared in Analysis Log, the result is available.
Then right click on Flow in the Study Task pane and select New Plot.
Scroll down the available results, select Node layer number from the list and select OK.
Would like to have Node layer number in Mesh Diagnostics tool.
Berndt
References:
Solver message 304920
