Hi guys.
I recently installed the Autodesk product Moldflow Adviser and Design as I am currently working in a project related to plastic injection molds. Moldflow Adviser is working properly, however, I can not say the same for Moldflow Design. I have a computer with a dedicated video card of 6GB (VRAM) and as a result I have an OpenGL version 4.4. Nonetheless, it seems that Moldflow Design is not recognizing the OpenGL version, as I am constantly receiving the message "you need to upgrade to OpenGL 3.0 or higher, you have a fewer version", which is clearly not true.
Do you guys happen to have faced the same error message, and if so, how were you able to solve it?
Many thanks.
Hi @mincho_166,
Welcome to the forums!!
Since you mentioned that you have a dedicated video card of 6GB, is this the computer's integrated graphics (for example, Intel) or is it an added graphics card (for example, an NVIDIA or AMD card)?
Sometimes an integrated card is used by default, which may occasionally cause issues depending on the specs/if it's updated to the latest Driver. One thing you can try is to go to the graphics card manufacturer's website to check the latest driver has been installed for that particular card.
A second suggestion would be, if Design is using the integrated card instead of the desired card, to manually switch Moldflow Design's graphics preference to the added graphics card.
The following link on Lenovo's support website describes how you can check when a program is using the integrated graphics vs an added graphics card. It also instructs on how to change this manually if you would like to switch to the more advanced card.
Hope this helps!!
Hi @mincho_166,
Any luck with updating and/or specifying the graphics card?
We also have this same issue with DFM on a workstation with 2 NVIDIA Quattro K4000 graphics cards. All of our moldflow products (Synergy, Insight, Advisor, SimStudio, Communicator) work just fine.
We updated the graphics card drivers, and verified that we have OpenGL 4.0 on them and we still get this error.
It is frustrating that the lowest intensity moldflow product has an issue on the workstation yet everything else works just fine.
We identified an issue with the method we run when Design is loading that checks for OpenGL driver version.
We need to check that because we use some functionalities that only exist from OpenGL 3.3 onwards.
However, some video cards mis-report the version of their OpenGL drivers (reasons for it can vary).
The best we can do about it is to remove that test, as most drivers these days have all the relevant extensions.
David Margalit
Moldflow SE
Hi Kristen, and thank you for your answer.
First of all, I am sorry for the delay in the answer, I've been very busy with other projects .
Then, going back to the matter at hand, I have an added graphics card (ASUS STRIX GTX-1060). The card is fully updated and I have checked that it is selected by default (therefore, I am not using the integrated graphics of my CPU). I have checked the provided link, however I am still facing the same issue.
Any other possible solution?
Thank you in advance for your help.
Best regards,
Hi @coryli @mincho_166 @andrewgeneralelectric @kristen.kilroy
I am happy to announce the fix to this issue (which was basically old version of a .NET OpenGL 3rd party layer) is now incorporated into our code and will be available in the Moldflow Design 2018.1 release (2 months from now).
We have tested this fix on different machines that had this issue reproduced on them, and they all seem to work fine now (without any message about OpenGL version).
Please note that it is still recommended to only run Moldflow Design on real machines (not VM), without Remote-Access from a different machine.
David Margalit
Sr. Software Engineer
Simulation Moldflow, DLS Products
DIRECT +61 3 9751 8142
MAIN +61 3 9720 2088
259-261 Colchester Road
Kilsyth South, Victoria 3137, Australia
As reported by others in this thread, Moldflow Design 2018 has issues detecting the OpenGL version available, other applications in the package work fine. I have the 2018.1 update installed (ama_Update1-64bit.msp) but it has made no difference. Is this the update you are referring to?
I have an NVIDIA Geforce GTX 750 Ti with a recent WHQL certified driver. GLView says this card supports OpenGL 4.4, but it also has an entry for 'GDI Generic (No Acceleration)' that says it support OpenGL 1.1. Presumably, it is defaulting to this 'device' (which is not a real device that appears in Device Manager) instead of the NVIDIA card. The control panel for the NVIDIA driver does not let me specify a default graphics card as suggested earlier. I've also tried adding a 3D settings profile for the "C:\Program Files\Autodesk\Moldflow Design 2018\bin\S4DViewer.exe" executable, with full performance and other options turned to the highest setting.
Is there anything else I can do to force it to run?
2018.1 was not released as an MSP. It's not a service pack, but a full installation of a brand new release. We don't do Service Packs anymore, but only UDB update releases (which is what that file is).
That file is the Adviser 2018 Update 1 MSP file.
This is not the Adviser 2018.1 revision (which is only available as a full install)
As I mentioned before: Moldflow Design 2018.1 does not have this problem anymore
Okay, thanks for the explanation. As I have installed a free educator network licensed version (for the University I work for) presumably this new release is not available? It's not listed in my Autodesk account, nor is this newer release on the available products list.
I am sorry but I am the software developer. I don't deal with licenses and release schedules.
I suggest you contact your Autodesk customer service/sales-agent regarding to this.
I'm having the same issue with MoldFlow Design 2018. Moldflow Advisor and Moldflow Communicator work just fine. I keep getting a message that "Version of OpenGL installed on this computer is 1.1.0. This product requires a graphics card that supports OpenGL 3.3 as a minimum...". I've got a 1050 Ti that supports OpenGL 4.5, so I'm not sure what's going on here. I've even made sure to run the program using the graphics card by right-clicking my shortcut and selecting the Nvidia card under "Run with graphics processor".
Thanks for the help guys! For those who have an education license, how were you able to upgrade to 2018.1 or 2018.2? It doesn't appear to be available to me.
