Dear Moldflow Adviser User Community,
We are very happy to let you know that the Moldflow Adviser 2025 release is available! Though this shortly the release of Moldflow 2024 earlier this, year, the new release is packed with a lot of net content. You can find an overview slide below.
What's in it
The main features of the release are:
- Search for materials with recycled content in the material database.
- Expansion of support for Histogram and Min/Max plot options.
- 3D flow and warp solver speed improvement.
Besides this, we fixed over 150 bugs from previous releases.
IMPORTANT!
- To speed up the 3D flow solver we changed the file format of the .of1 file. This new format is readable by the Moldflow 2025 products (Synergy, Adviser and Communicator), but if you read a 3D flow result from Moldflow 2025 into a prior version of the software, you will not see Fill time results. Our recommendation is to upgrade everybody you work with to the Moldflow 2025 release (Moldflow Adviser, Moldflow Synergy and Moldflow Communicator). NOTE: Moldflow 2025 will continue to be able to read the prior result format.
Getting started
The Moldflow 2025 release is a full new release that can be installed next to your other Moldflow releases. You can download the Moldflow 2025 release from Autodesk Accounts > All Products and Services. As with the installers in the last few years, Moldflow Insight Multi-user (aka. Network licenses) can use either the Moldflow Insight Ultimate or Moldflow Synergy installer (as they are the exact same, for Windows).
Using the ‘Custom Install’ option, you can create an installer that includes license server information, and IT Administrators can create deployments that can help with the roll out across an organization. During creation of the custom install/deployment you can specify the license type you use; ‘Network’ or ‘Autodesk ID’ (for named user). Creating a deployment this way is highly encouraged specifically for companies using Token Flex (TFLEX) licenses.
If you do not pre-configure your licenses in Autodesk account, the product will be installed assuming you are using a Named User license. You can switch to a Network license using the Moldflow License Configuration tool (mlc.exe) you can find in your Moldflow 2025 product folder.
Documentation
More detail on the Moldflow 2025 release can be found in the online help pages in the ‘what’s new in Moldflow Adviser 2025’ section.
Free companion product (Communicator).
Moldflow Communicator 2025 is available for free from the following page (link). This includes installers, installation instructions as well as sample files. New for Moldflow Communicator is the option for dual unit display (US English and Metric) in the results (Option > Results tab)
Documentation
Best regards
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
