I recently started using moldflow adviser and still in beginner level.
If i run analysis for some round part as shell or bowl what are the parameters to take care for getting better results for ovality.
I tried to tweak mold temperature and melt temperature results seem to be similar.
for basic understanding can you help me with how to start for single cavity and multiple cavity can runner and gate directly created in moldflow advisor.
Can you share some case study and link to start with topic.
Nilesh
Hi @Anonymous
welcome to Moldflow family
Please go thru the below links for basic understanding on single & multi cavity modeling and runner system modeling.
Single cavity modeling
http://help.autodesk.com/view/MFAA/2017/ENU/?guid=GUID-0C8ED9EA-205D-405C-9247-71ED3128663F
multi cavity & Family mold
http://help.autodesk.com/view/MFAA/2017/ENU/?guid=GUID-1DA81B9C-A8DB-428C-B9BA-81CA93B451EB
Please go thru the below links for modeling gates & runners
http://help.autodesk.com/view/MFAA/2017/ENU/?guid=GUID-9E07097B-4669-45B1-AA52-CAA31ED4B772 (runner creation using wizard)
http://help.autodesk.com/view/MFAA/2017/ENU/?guid=GUID-650F0B0C-9FC6-43BF-AC1D-62851DFFE23A
Gate location plays major role in controlling the warpage; can you share some images on your component with predicted warpage?
Hope above links are helpful to you
Hi Nilesh,
just to add to the good information provided by @mppkumar
In Adviser UI click tab Start & Learn
There you have Tutorials and Videos.
Videos has Essential skills, with model a single-cavity mold and multi-cavity mold.
Link to: Moldflow tutorial models
ASMA is Autodesk Simulation Moldflow Adviser
By this you have close reach of the basics.
Berndt
Hi Team,
i was running through analysis for one part.
The result what i am getting for the war page are not good what possible gating option can be suggested and processing parameter.
would like to improve results material used is PA66 GF30%.
it is difficult to give recommendations on a single picture and no model.
Is the issue related to fiber orientation or difference in volumetric shrinkage?
Now, to understand what contributes most the deflection , Deflection, all effects result, review the differential results:
Deflection, differential cooling
Deflection, differential shrinkage result
Deflection, orientation effects
The Deflection, all effects result combines differential cooling, differential shrinkage and orientation effects to show the final part warpage.
The Deflection, differential cooling result shows the final part warpage due to uneven cooling.
The Deflection, differential shrinkage result shows the final part warpage due to the variation in shrinkage across the part.
The Deflection, orientation effects result shows the final part warpage due to the material orientation throughout the part.
If the material is fiber filled, this corresponds to the fiber orientation in the part.
If no cooling circuits and Cool analysis, it is 0 (might show very low numbers theoretically)
So main contributors are :
Now, as PA66+GF30%, it is probably Deflection, orientation effects, causing the main issue.
The fibers often takes over when aroun 20- 25%
But you should review each results to be sure, and to know how to improve.
Reducing warpage due to differential shrinkage
The main ways of influencing differential shrinkage effects are:
Designing packing profiles.
Reducing part thickness variations.
Reducing warpage due to orientation effects
The three main ways to influence orientation (apart from choice of material) are to change:
Molding conditions.
Model thickness.
Gate locations.
When you know main contributor to warp, you can focus on how to resolve issue.
Hope this helps.
Berndt
wall thickness is not major issue
I have attached picture for fiber orientation and differential shrinkage.
Is gating suitable i have tried center gate but results remain same
from differential shrinkage and orientation effects, differential shrinkage seems to contribute most.
Check your packing profile, that pressure level and time is sufficient.
(default is packing pressure 80% of injection pressure, and 10s)'
Look at Time to reach ejection temperature result plot, to get an understanding of how long packing time can be.
The Time to Reach Ejection Temperature result plot also guide how long time packing pressure can be applied.
It is a bit below Transition temperature, so a little bit shorter packing time could be applied probably.
Background/reason:
Time to freeze is depending on the Transition temperature, Ttrans, in material details tab Rheological properties.
This is the freezing temperature for material.
Time to reach ejection temperature result plot is base on Ejection temperature in material details tab Recommended Processing.
So, basically, the time when part could be ejected.
As lower temperature, it will take longer to reach ejection than freeze.
Hope this helps.
Berndt
Hi bernor,
As you explained i have checked my packing profile and it was default.
Time required for ejection i have try to show image.
As you suggested i have tried to check material processing recommendation.
And set mold temperature 95 and melt temperature as 300.
Material 70G33L NC010
How much packing pressure needs to change.
can you check and share your feedback would like to get results under 0.5mm
Nilesh
Hi bernor,
As you suggested i have check the packing profile is default.
Ejection time required i am attaching a image.
I have changed the mold temperature and melt temperature still no improvement in results.
I have selected 70g33L NC010 material.
Can you check and revert with solution for right way to getting minimum warpage.
would like to control under 0.5mm.
Nilesh
Hi Nilesh,
I will download model and I will have a look on the model you shared.
Do some analysis and see if I can give you some advice.
Kind Regards,
Berndt
Hi Nilesh,
made simulation as shown in pictures with 2 gates.
First: Used Design Adviser to review thickness:
Warp - Cause of Deflection:
Main contribution is differential shrinkage. Orientation effects do contribute too.
As the gates are on thin area of rim, gate on thin thickness area – Time to reach ejection temperature shows rim will freeze off earlier than overall general part thickness, causing packing problem, which means high volumetric shrinkage and probable warpage problem and dimensional issues.
Rim will freeze off earlier than overall general part thickness,
Inner area will continue to shrink more
This will bend the thinner outer rim, as it cannot resist the forces
Next steps to test:
- Gate in thicker thickness region
- Increase packing pressure and packing time
Further: Review part design - can changes be made to improve to design for manufacturing and application?
Different restrictions due to part and mold design might not make optimum gate position possible.
Look for best compromise, with Moldflow Design Principles in mind.
Will do some more simulations and update.
Berndt
Thanks Bernor,
For taking time and giving the solution.
Can we create thick section near the gating area purposely so that it might work for possible gating.
Gating in center is not good idea for glass filled fiber as it might not give uniform fiber distribution.
As you have shown ejection time 32s.
how much packing needs to be applied in parameter considering ejection time.
If design cannot be improved how much minimum we can obtain through processing.
Do you think adding cooling lines and doing analysis will improve the results.
Can you share processing parameter considered during analysis.
Nilesh Nagare
Hi Nilesh,
replies on your questions:
> Yes, I believe so. This is many times done, to ensure an open channel for packing.
Make a small redesign, and a simulation to verify.
> Okay. But you can use simulation to test different options.
> yes the maximum is about 32s - but around 12s in 3 mm thickness area
> about 12s in 3mm thickness region.
Background/reason:
So, basically, the time when part could be ejected. As lower temperature, it will take longer to reach ejection than freeze.
For packing in Adviser, using the Time to reach ejection temperature result plot and investigating times in gating area is a good way
to find maximum time to pack.
Now, depending on difference between Transition temperature and Ejection temperature, you could change Ejection temperature to a value
closer to Transition temperature if you wish to fine tune times. But initially not necessary, I would say.
> Basically nothing... main cause is differential shrinkage and orientation effects, and if you cannot change to pack the part,
well then you are stuck.
> First fix main cause, then test cooling.
In simulation we want to have a big processing window for production, and not narrow it in design stage.
> Sure.
As time to reach ejection temperature is about 12s in 3 mm thickness I used 12s packing time.
Some materials has measured Shrinkage Properties.
This could help to understand pressure level and volumetric shrinkage
Zytel 70G33L NC010 : DuPont Performance Polymers has it, and 2 points for 3mm.
So I decied to go for a mid value, 60 MPa packing pressure.
The volumetric shrinkage should then be around 4-5%
Automatic for injection time, switch over and cooling time.
Berndt
Hi Nilesh,
Gate in 3mm thickness area
Gate on same side , but in 3mm thickness area
Packing 60MPa for 12s
The part is now flatter – so an improvement.
Main contributor to deflection is now orientation effects
Middle bend is shrinkage and orientation effects
Add some results comparing different gate positions.
To conclude:
Gate on thicker area (redesign if needed)
Ensure sufficient packing pressure and packing time
Next steps:
Add runners and cooling to verify when first improvements completed.
Berndt
Thanks Bernor,
For quick response
It helped me to get more clarity on the topic and also new learning each day.
Appreciate your efforts in sharing knowledge.
Nilesh Nagare
You are welcome, Nilesh.
I am happy to help and share (when time permits )
If you have time, there is more of it:
https://www.youtube.com/user/autodeskmoldflow
Berndt
