Hello
Can anyone just let me know how can I implement the exact molding machine parameter in Moldflow. As there is difference between the actual Molding process parameter and in Moldflow process setting. for example how can i apply this process in Moldflow.
Solved by bernor_mf. Go to Solution.
you can set up an actual molding process in Moldflow Insight, which has more details of process setup and result.
Those details are available in Moldflow Adviser
Setting up an Moldflow Insight Analysis to match an actual molding process
Video:
Matching Simulation to Actual Molding in Autodesk Moldflow
Autodesk Knowledge Network article:
How to match simulation to reality with Simulation Moldflow Insight
You can set injection profile as on IMM.
Things like melt mixing, screw rotation is not possible to set.
I assumed a good melt is mixed, that is dozed for injection.
Hope this helps.
Berndt
Hello berndt
Thanks for valuable information
Thanks and regard
Akshay Pawar
