Assume that I have plastic bottle of drinking water and want to create cooling channel for it in a spiral shape just like spring shape, then can it be possible to create?
Solved by bernor_mf. Go to Solution.
Solved by kristen.kilroy. Go to Solution.
Hi @jay21min,
Welcome to the forums!
We have the ability to model conformal cooling via 3D cooling channels (imported from CAD geometry) in Moldflow Insight/Synergy (see: AMI Online Help: Create 3D Channel Mesh), however with Moldflow Adviser, cooling geometry is limited to only beam elements. This results in it not being able to easily capture curved lines of a spiral cooling system, similar to what you are describing.
In Adviser, cooling channels can be imported via *.iges curves from CAD geometry (see: AMA Online Help: Importing a Cooling System), however the same limitation occurs when doing this as described above.
I mocked up an example below showing why this becomes an issue. Notice in my example how an imported helical channel results in hundreds of slivers created from beam elements. Though the geometry looks represented, when attempting to analyze, this will either fail or continuously load (possibly freeze up) as Adviser tries reading all of those beam elements.
You can give it a try, however I would probably suggest to try squaring off the channel paths (maybe try hexagonal or octagonal shape instead) to help simplify the channels so it will load more easily.
Hope this helps!!
Hi Kristen,
I am facing the the same problem while running the simulation with imported runner. Is there no way to control the number of elements in beam?
Regards
Paul
Hi Paul,
I'll cut in here.
There is no way to control number of beams when importing a curve from iges to Adviser.
It uses a hardcoded choorda tolerance.
You need to split the curve in CAD.
Either the system has a neat function for this or...
you have to manually draw some lines in 3D sketch mode, with points on curve.
See attached pictures:
The imported iges file as:
1) curve/spline
2) lines
Hope this helps.
Berndt
Hello Berndt,
Thanks a lot. Now I can run the simulation smoothly.
Regards
Paul
Respected all,
I am glad to see all conversation among you people.
I tried to create conformal cooling channel, but could not do.
I humbly request for you to help.
I can't attach product for which we have to create conformal cooling channel, because the site is not accepting.
So,I send you all that file individually.
Take cooling channel diameter as 8 mm.
Center line distance between two cooling channel as 22 mm.
Distance between the outer surface of the product and cooling channel is 14.5 mm.
For more clarification of cooling channel see below figure.
The given figure is just for example.By mistake,in this example cooling channel and product is not matched properly.The front portion of product is left without cooling channel.So,don't do that kind of mistake. The cooling channel must cover the whole outer body of the product and match properly.
After creating cooling channel, please try to check that whether it is suitable for simulation of cooling time or not.
Looking ahead to hear from you.
Thanking you.
to get the site to accept file to upload you need to compress to format like .zip , .rar which are valid extensions:
I think you could fix this in CAD system by draw point to point lines on spline for conformal cooling.
1) have the spline in CAD
2) draw point to point lines on spline, in a acceptable division for layout
3) delete spline
4) export lines to iges format
5) import lines as cooling channels to Adviser
Can you attach spline iges file?
I have asked for improvement on Moldfow Ideastation:
Adviser import runner or channel: Add Option to set division and/or chord height
Vote it up if you like it.
Berndt
Valid extensions:
3dp,3ds,ach,ai,art,ass,asx,avi,axm,bm,bmp,cfz,chm,cps,csv,dbf,dcl,doc,docx,dst,dwf,dwfx,dwg,dws,dwt,dxf,dyf,dyn,eco,env,eps,esri,f3d,f3z,fbx,fm,gif,gz,gzip,iam,ics,ide,idw,iks,ipn,ipt,jfif,jpe,jpeg,jpg,log,lsp,mac,max,mb,mp4,mpg,msg,nc,nc1,nwc,nwd,nwf,obj,obk,pat,pc3,pdf,pkt,png,png,ppt,pptx,prj,psd,rar,rfa,rft,rlf,rtd,rvt,sat,sdf,sdf,sdf2,sdf3,shp,shx,simstudio,sldasm,slddrw,sldprt,step,stl,stm,stp,svf,svg,text,tif,tiff,txt,vcf,vtf,vtfx,wmv,xls,xlsx,xml,xps,zip are the valid extensions.
Respected, Mam.
Thank you so much for your effort of conformal cooling channel generation.
But, still I am facing that problem.
If you help me to create conformal cooling channel of hand torch, I would be very grateful to you.
I need you email address so that I can send object.
