There is a way to find the maximum flow lenght value after a fill analysis?
Solved by GIAMPIETROPICCOLI7095. Go to Solution.
Solved by bernor_mf. Go to Solution.
if I understand this correctly you need a distance value after a completed Fill simulation, a distance value that is from injection location cone to end of fill, last point to fill, and a calculated maximum length from node to node.
Unfortunately there is no such distance or flow length value available from result to get it automatically.
The only way is to use the measure tool and do repeated measures, note distance and add up, to capture the flow length.
Or cut part in CAD system, concatenate curves and lines and measure.
Maybe something to improve in Adviser, and you can put a suggestion at Moldflow Ideastation:
Berndt
Ok
Many thanks for your answer.
I will suggest this new result option
Bye
Giampietro
