SIR,
IS THERE ANY WAYS TO CONVERT OR EXPORT MOLD FLOW FILE (.mpa) in to ANSYS COMPATIBLE FILE(.db) or ANSYS WORKBENCH
if you use Moldflow Adviser, there is no option.
See: Compare products Moldflow Insight and Moldflow Adviser
Software interoperability
You need Moldflow Insight.
You can then use Helius PFA or mpi2ans
Helius PFA Working with Moldflow
Moldflow Insight: Interface to ANSYS
Hope this helps-
Berndt
you need a valid license of Moldflow Synergy and Moldflow Insight:
1) If you are entitled to download, it is available from your account at: https://accounts.autodesk.com
2) Your CM, Contract Manager or Software Coordinator can download the software.
3) You need to buy locate a reseller: http://www.autodesk.co.uk/resellers/locate-a-reseller
Hope this helps.
Berndt
found this in another thread, if you belong to an educational institute:
4) Moldflow Insight is available to educational institutes through a granting process.
This sounds more intimidating that it is, but it's primarily done because the Moldflow Insight licenses are not compliant with the standard requirements for educational products.
To apply for the grant, you can send an email to moldflow_edu_grant@autodesk.com from your university email account
Berndt
