Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
ディスクゲートについて - About Disc Gate
1 ANTWORT 1
Nachricht 1 von 2
Adts1222kinaco
173 Aufrufe, 1 Antwort
歯車のモデルにディスクゲートを追加したいのですが、どのようにすればいいですか?
How can I add a disc gate to my gear model?
1 ANTWORT 1
Nachricht 2 von 2
bernor_mf
als Antwort auf: Adts1222kinaco
@Adts1222kinaco
google translated from Japanese to English. :lächelndes_Gesicht_mit_lächelnden_Augen:
Regarding modelling of manually trimmed gates, such as disc or diaphragm gate there is limitations in Moldflow Adviser.
There is no such modelling entities available for disc gates.
In Moldflow Insight and Moldflow Synergy (UI) you can work with mesh.
Workaround for Adviser:
I believe you need to model the disc gate together with cavity gear model in CAD, then import to Moldflow Adviser
Reference:
Disc or diaphragm gate
Manually trimmed gates
Video example: Autodesk Moldflow Fan Gate Modelling
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Tags (3)
