Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
What is the meaning of the gray and black lines?
1 REPLY 1
stellab123456
674 Views, 1 Reply
Hi. I try to print an STL file that is all in black and gray lines. I can't select or do anything. How can I fix it?
1 REPLY 1
MagWeb
in reply to: stellab123456
A stripe pattern on a surface means that you are watching the backside of the surface. In most modes of MM this stripes are in pale pink. In SELECT selected back faces show a black/grey pattern.
If an object is flipped all over it is a cavity (inside a infinite world filled with material).
Easily fixed if this flipping happens all over the object:
Hit Ctrl+A to SelectAll and run Edit/FlipNormals in SELECT. > Now the Object should be white as usual...
Gunter Weber
Triangle Artisan
