Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Unhandled issue on Export of several textured objects
1 REPLY 1
MagWeb
299 Views, 1 Reply
If you have several textured meshes added to your scene:
and you do something which joins the objects to one (e.g. Combine, some Boolean or saving the whole scene in one OBJ) you'll find that MM's obj export doesn't handle multiple textures properly. On Export it may save one textured material only.
If you reimport such a OBJ you'll see only one texture being used:
A closer look at the source files shows the problem: Both source objects come with the very same material definition label. Opening OBJ files and the corresponding MTL files in a text editor you see that both use "defaultMat" (orange) while their MTL point to different texture images(green). That's why both source OBJs load fine on Import.
Against saving the scene as a MIX file (which handles that properly) on OBJ Export MM keeps "defaultMat" for both surfaces and saves (and links to) a single texture image. This results in a texturing as shown above.
To keep different textures in such a case you need to edit the material label in one of the source OBJs and its MTL (here I added a "1") before Import:
Now MM saves the different source surfaces as different materials and on reimport you will get the proper result:
Gunter Weber
Triangle Artisan
1 REPLY 1
hfcandrew
in reply to: MagWeb
Thatès some advanced MM work! Thanks!
