Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Trouble selecting very thin faces
1 REPLY 1
pharma_owns
281 Views, 1 Reply
Hi!
Been using meshmixer for quite some time now but sometimes I have trouble selecting/deleting very thin triangles on a mesh. Even with zoom, selecting back faces, or using really big size brush value when selecting, I end up with this very thin blue (edge) lines and can't get rid of them.
Any trick?
Thanks!
Labels (1)
1 REPLY 1
MagWeb
in reply to: pharma_owns
First thing is to try EDIT/CloseCracks to weld open boundaries.
If there are still cracks try BrushMode = SphereBrush. This mode selects faces within a sphere and doesn't "jump" from one side of the crack to another.
Another trick is to select and separate the region around such a crack temporarily so that the tiny stretched face isn't connected to the mesh any more. Now select a region on the mesh to keep, ExpandToConnected > Invert > Discard. That done Combine the separated piece again > CloseCracks to weld it > Inspector to repair the hole.
Gunter Weber
Triangle Artisan
