Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Triangle Tolerance
1 REPLY 1
tshufordhicks
264 Views, 1 Reply
Triangle Tolerance
I just recently came across Meshmixer for 3D printing but I have a few questions before I begin using the software. How many triangles can Meshmixer tolerate?
Is it necessary to do retopology and lower polycount for 3D printing?
Labels (1)
1 REPLY 1
hfcandrew
in reply to: tshufordhicks
Depending on your computer power, may get framerate drop off at 1M, and some more complex functions seem to take very 5 minutes to compute, or some boolean operations may fail.
To reduce a triangle count:
Select>Edit>Reduce
http://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-54087649-E962-409E-8565-F646BDA80B33
Not necessary though. Only use this if the above mentioned issues are interfering with your CAD work, such as in needlessly high res scans.
