Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Tree support too close to model
1 REPLY 1
florian.mueller9393
1071 Views, 1 Reply
Adding custom support posts is a very powerful tool for 3D printing, that I often use. However I often have trouble removing the support because the posts "hug" the model too close. I would love to see a setting like "Distance between Model and support post". Or is there any other way to do this?
(I dont have trouble at the support tip, but at the "main body"/"post" of the support).
The example in the picture looks just fine, but I got other models, where it was too close to the model. Also, I often use "vertical expansion" in my slicer, which adds to the problem.
Another thing I would like to see: When adding a strut that goes through the model, it automatically wraps around ("hugs") the model 😉
1 REPLY 1
The only way I know to get a bigger distance posts/object is some scaling trick:
Let's say the object is 50x50+50
1. Reduce Units/Dimensions at a certain factor (let's say 0.5 > so it's 25x25x25 now)
2. In Overhangs use the same factor 0.5 for all unit related parameters(e.g. target post diameter shall be 3: so set it to 1.5 )
3. GenerateSupports
4. Rescale via Units/Dimensions to the target size (50x50x50)
Gunter Weber
Triangle Artisan
