Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Transform Function Parameters
3 REPLIES 3
drdds2030
217 Views, 3 Replies
Is anyone aware of a way to set parameters for the transform function? To better explain this, I want to make a "dynamic" object that can be moved in multiple planes by using the transform tool, but I want it to stop at certain points on the different planes so it cannot be extended past said point (so essentially creating movement parameters).
Any help or suggestions would be appreciated!
3 REPLIES 3
hfcandrew
in reply to: drdds2030
You can automate the process with the mmAPI, but that is a bigger undertaking if you do not know how to code.
You can also drop pivots that can be 'snapped' to when using the transform tool: http://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-EDB35D1E-13EB-4689-A83E-DD8C1D71CDC2
drdds2030
in reply to: hfcandrew
Thank you for your response! I tried that but I'm not able to get the object to snap onto my pivot for some reason. As there are multiple "snap to" options, which pivot drop point would you recommend I select?
Much appreciated and thanks again!
hfcandrew
Oh you are right, I mixed up align with transform.
I don't think transform has that ability. Align is the closest, and it takes a bit of setup:
https://www.youtube.com/watch?v=SSOMVxEjNPw
