Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
thicken surface towards outside direction
4 REPLIES 4
ZHLU
1150 Views, 4 Replies
Hi everyone,
I was trying to thicken the surface of a hollow model towards outside direction by selecting outside surface and then extruding it. But every time I selected with brush, the inside part was always included by default. Does anyone have any idea on how to manage that?
Thank you so much!
4 REPLIES 4
MagWeb
in reply to: ZHLU
You're using The Sphere BrushMode > anything inside a brush's sphere is selected.
From MM Help:
"There are three Brush Modes:
  • Unwrap mode selects a highlighted, connected patch of the surface around the brush.
  • Sphere mode replaces the grey patch with a semitransparent Sphere, and selects everything inside the sphere. The key thing with Sphere mode is that you can select disconnected regions, so it is good if you are selecting in areas where there are lots of disconnected meshes.
  • SphereDisc mode is a sort of hybrid, that uses a Sphere but limits the selection to those faces that are connected (via some path on the 3D surface) to the point under the cursor. "
The Unwrap mode should do it:
To thicken a selected region Edit/Offset (with Connected checked and SoftTransition set to some value bigger than zero) is the proper tool:
Gunter Weber
Triangle Artisan
ZHLU
in reply to: MagWeb
Thank you so much! It works very well! Would you mind explaining a bit more on why "offset" instead of "extrude-normal" to do thickening?
MagWeb
in reply to: ZHLU
If you want to thicken a convex surface Extrude in Normal Direction gives the same result as a connected Offset with zero transition. One difference is that Offset allows to define a Transition from the source level to the offset level. Against that Extrude will result in a harsh stair (Which needs to be smoothed out later.
On a concave region selected Extrude might run into self intersections:
E.g This selection
results in this Extrusion result (cut to show the self intersection):
Against that Offset tries to solve those self intersections:
Gunter Weber
Triangle Artisan
ZHLU
in reply to: MagWeb
Thank you! That's very helpful!
