Tapper shape transformation
hadestrina
hadestrina
Community Visitor
Community Visitor
Hi everyone. I have a rectangle shaped object .imagine a wall with parallel sides .how can i tapper all the sides uniform so the top of the wall will be thinner than the bottom without losing its shape ? When im trying the soft transform and sliding the white rectangle of gizmo left right,my whole shape is following the slide direction.not tappering to the top surface.thanks a lot
hfcandrew
Select > Edit > Transform
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-795CC791-2F63-42FC-B58A-B688C5970CE9
and then click and drag on the centre white cube to uniformly taper.
hadestrina
Community Visitor
Community Visitor
Can i tapper with degrees angle? I want to rotate the sides of my shape in  specific degrees, all of them simultaneously. Think about a pyramid shape
hfcandrew
Yes, but only indirectly.
You can either 1) Do the math on paper for the final width and height that gives you your desired angle.
or 2) Set a separate plane object to the angle you want, then match your taper to that just by eye.
