Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
stl model how to repair
1 REPLY 1
fprico
352 Views, 1 Reply
I have an stl model of a car I want to delete the front grill and make the front smooth without the grill, how can I make this?
1 REPLY 1
MagWeb
in reply to: fprico
Sorry this is a pretty rough description of your issue.
Is the region you want to get rid of a not connected part? If so you could select a snippet of it, hit E to expand to connected and hit X to delete it.
Several other options as e.g. Select the region and run Deform/Smooth with radical settings or run Edit/EraseAndFill and more. Depends much on the way the front grill is connected to the rest of the surface....
Gunter Weber
Triangle Artisan
