Spherical Triangles
Spherical Triangles
Spherical Triangles
I was following a tutorial on how to create a Low poly model with triangular surfaces. How come all my surfaces stay spherical instead flat surfaces?  (the second image is what I'm after)
hfcandrew
It's working fine, its just a default graphics setting issue, meaning the the wrong rendering mode. Read here.
Also hit 'W' to view the wire frame.
I'd lower the triangle count even further too for a better result. But to keep some definition around the ears, select them separately and leave those as a slightly higher density.
