Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Smothered Effect on Boolean Difference
8 REPLIES 8
Message 1 of 9
georgekenefati98
548 Views, 8 Replies
I am trying to perform a simple boolean difference using two models. However, there is a smothering effect which removes all resolution on the cut. I am not sure how to resolve this issue.
I have included screenshots of the settings used and the result of the cut.
Any suggestions you may have are appreciated.
Thanks.
8 REPLIES 8
Message 2 of 9
I'd suspect the mesh density is too low.
Or its working fine, and its just a graphics issue, meaning the the wrong rendering mode. Read here.
Message 3 of 9
Thanks for your response. I tried exporting to check if it was a graphics
issue and the STL looks smothered as well. How can I fix the low mesh issue?
Message 4 of 9
Hit 'W' to see the wireframe. Select All>Remesh.
Every situation is different because every mesh is different. Unique little snow flakes they are. So if that doesn't work could you attach the files and also post a screen cap.
Message 5 of 9
Snowflakes indeed! I did not get it to work-- Attached are the files in a zipped folder, as well as a Screencast showing the operations and also the translations of the two models.
Thanks in advance!
Message 6 of 9
I didn't see the Screencast in my reply, so I am placing the link in this message.
https://knowledge.autodesk.com/community/screencast/bcb0d939-8bba-4171-b803-6784dbf46146
Message 7 of 9
nfarley
in reply to: georgekenefati98
Have you tried I checking the box “auto-reduce results”?  This often leaves a sharper edge.  If not, I agree...remesh first.
Message 8 of 9
hfcandrew
in reply to: nfarley
Yep works fine for me if you either:
A) 'Remesh' to a higher density
B) Uncheck 'Auto-Reduce' results
C) Lower 'Target Edge Scale' to ~0.2mm
D) Really just play around with the menu settings until it looks good enough. Read this: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-355503DE-889B-4168-8398-084F9BBD508B
Message 9 of 9
Thank you very much for your help 🙂
