Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Smooth Boundary Borders In Transparent/Translucent
5 REPLIES 5
sarf2k4
529 Views, 5 Replies
I recently discovered that I turned on basic rendering and unable to go into transparent/translucent object. However, turning the option off do enable me to use the shaders but the orange boundaries made the highlighted orange in smooth boundary option became transparent/translucent. Turning on the basic rendering option do solve the problem but I'm unable to use shaders for the transparent/translucent object.
How can I have both shader enabled but without smooth boundary highlight becoming transparent?
5 REPLIES 5
MagWeb
in reply to: sarf2k4
This seems to be a graphics card drivers issue. To render things properly the GPU driver needs to support Qt 5 (Qt is a  framework MM uses to render stuff). So please check if you can update your graphics driver. Maybe  a lacking driver was the reason why you enabled basic rendering ? Maybe you also try MM 3.3 instead of MM 3.5 which needs less requirements concerning GPU.
Anyhow. This is just a temporary rendering glitch. As soon as you accept the tool you should find rendering being fine again.
Gunter Weber
Triangle Artisan
MagWeb
in reply to: MagWeb
Maybe you can get rendering in SmoothBoundary by switching on wireframe rendering temporarily (hit W to toggle on/off).
Also disabling EnableAnti-AliasedRendering and ShowViewCube (>Preferences>General tab) might help?
Gunter Weber
Triangle Artisan
sarf2k4
in reply to: MagWeb
Turning on wireframe during Smooth Boundary operation stays the same where the grey coloured shader/faces became orange translucent even with viewcube and anti-aliasing disabled.
I need viewcube to achieve more zoom as I work with precision, reset view to home (probably that what's you call it) with V enables me for more zoom. Disabling viewcube, I can't zoom further.
I am on the latest nvidia driver of v419, should be stable recommended update by nvidia.
I also switched gpu rendering to nvidia instead of integrated. Using GTX950M
My meshmixer is version 3.4.35, year 2017 from About Information.
I think I can live with basic rendering
MagWeb
Some tools need/use transparent shader (e.g. PlaneCut, Align, MakePattern, an object set as Target a.s.o)... So BasicRendering is not an optimal solution.
Just some hints about navigation without ViewCube.
- In the Hotbox (Hold down Space) you can enable Snap:
If active (dark) the cam snaps to nearby main directions (e.g. Top, Left, Right...)
To zoom in closer than the nearby clipping plane allows: SELECT the area of interest and do menu: View/RecenterView.
Now the selection is used to fit to view and also the clipping plane is reset relative to the selection.
Gunter Weber
Triangle Artisan
sarf2k4
in reply to: MagWeb
For now I'm good with basic rendering, even for plane cut and others. I never understand what the camera stuffs that you pointed out like what are their differences between each.
I also posted a question here https://forums.autodesk.com/t5/meshmixer/over-zooming/m-p/8408728#M492 about zooming without clipping the model, I often use recenter view (V hotkey if viewcube enabled) and the idea of going to the menu bar to always recenter view is so bothersome because of 2 clicks away instead of V at the keyboard and quickly navigate to the desired point.
Thank you for the solution on the shader and basic rendering option you pointed out
