Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Slicing
1 REPLY 1
146 Views, 1 Reply
Slicing
Hi please can someone help me?
I new to meshmixer, when I try to slice a file in half by going to plane cut moving to position I want and clicking accept.
Then click separate shells it seperates it into laods of files not the 2 that id expect? why is this?
cheers
Pete
Labels (1)
1 REPLY 1
MagWeb
Most likely:
Your source mesh is an object made of several surfaces not being connected.
If it is a scanning result there may be small outliers (scanning errors) floating in space.
If it is a modelling result it might be just a combination of different, maybe intersecting partial objects. In this case you need to construct a  single watertight mesh first (several ways... depends on the very case ... please post a screenshot).
Or:
Your source mesh is a single watertight shell but the cut hits the object several times (e.g. cutting off the peaks of several mountains)
Gunter Weber
Triangle Artisan
